Oldgal
May 29, 2024Aspirant
New RBR850 setup problems
Was running an old Hitron modem/router in bridge mode with RBR50 router and satellite and it worked like a charm for 5 years. I was getting reliable 750Mbps, which was a big bump up from the ISP’s ro...
- Jun 02, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Oldgal
Jun 02, 2024Aspirant
Used the MS Edge browser and that was the ticket. Updated the RBS to the latest FW (to match the RBR) and all seems to be operational. Many many thanks for the assistance!!
Jun 02, 2024Guru - Experienced User
Enjoy. 📡
