Timothy88
Oct 07, 2021Luminary
New RBR/RBS 750 firmware version 4.6.5.14
Got prompted for new firmware update. Not a chance I’m installing after the last debacle. Any release notes?
- Oct 08, 2021
Looks like it fixes somethings...
Dazza762
Oct 08, 2021Luminary
Have to agree. After the last update, I'll not be installing anymore until they've been out in the wild for some time.
Mastra11
Oct 08, 2021Apprentice
Hello, I have orbi RBK753 and I too have received the notification of this new firmware version 4.6.5.14 I have not yet installed it. Has anyone installed it works fine and without problems? Thank you.
- Talk2MikeOct 10, 2021Apprentice
I updated my RBK753 system (router plus two satellites) a few days ago and have not had any issues. Everything seems to be working fine.
- FURRYe38Oct 10, 2021Guru - Experienced User
Enjoy.
- kung_fu_curlyOct 14, 2021Aspirant
Still having issues since this latest update. I've factory reset everything and started again and still get the same issues. Devices struggling and usually failing to get an IP and my two RBS750s drop off and need to be restarted every couple of hours. I've not had any similar issues until I installed 4.6.5.14.
When the RBS750s drop off they get a solid blue light, I can leave them for hours and they remain like this with no connection via them until after a power cycle. None of the devices connected directly to the router seem to be effected by these issues but this is absolutely no use to me, I need the satellites to work reliably.
If you havent already done this update I would avoid it.
