Timothy88
Oct 07, 2021Luminary
New RBR/RBS 750 firmware version 4.6.5.14
Got prompted for new firmware update. Not a chance I’m installing after the last debacle. Any release notes?
- Oct 08, 2021
Looks like it fixes somethings...
Oct 08, 2021Guru - Experienced User
kung_fu_curly
Oct 10, 2021Aspirant
Shambolic update. My devices had been working fine until I did this update. Now the satellites go out or sync every half hour or so and devices struggle and mostly fail to get an IP. Armour seems to have gone into overdrive as well constantly giving me notifications that it's scanned a device.
- FURRYe38Oct 10, 2021Guru - Experienced User
Try a full power OFF for 5 minutes with the ISP modem and Orbi system, then back ON.
kung_fu_curly wrote:
Shambolic update. My devices had been working fine until I did this update. Now the satellites go out or sync every half hour or so and devices struggle and mostly fail to get an IP. Armour seems to have gone into overdrive as well constantly giving me notifications that it's scanned a device. - mschoenfNov 04, 2021AspirantYep… my internet has been going out every 30 seconds since the recent firmware update…
- FURRYe38Nov 04, 2021Guru - Experienced User
You may need to factory reset the system and power the system OFF as well.
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150287/highlight/true#M21560
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150391/highlight/true#M21575
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150417/highlight/true#M21579
mschoenf wrote:
Yep… my internet has been going out every 30 seconds since the recent firmware update…- mschoenfNov 04, 2021AspirantHey there thanks for the reply, if I factory reset will I have to re set up all my smart devices? Or will they auto reconnect in general? Will Ssid reset too?
