Timothy88
Oct 07, 2021Luminary
New RBR/RBS 750 firmware version 4.6.5.14
Got prompted for new firmware update. Not a chance I’m installing after the last debacle. Any release notes?
- Oct 08, 2021
Looks like it fixes somethings...
kung_fu_curly
Oct 14, 2021Aspirant
Still having issues since this latest update. I've factory reset everything and started again and still get the same issues. Devices struggling and usually failing to get an IP and my two RBS750s drop off and need to be restarted every couple of hours. I've not had any similar issues until I installed 4.6.5.14.
When the RBS750s drop off they get a solid blue light, I can leave them for hours and they remain like this with no connection via them until after a power cycle. None of the devices connected directly to the router seem to be effected by these issues but this is absolutely no use to me, I need the satellites to work reliably.
If you havent already done this update I would avoid it.
Dazza762
Oct 14, 2021Luminary
kung_fu_curly wrote:Still having issues since this latest update. I've factory reset everything and started again and still get the same issues. Devices struggling and usually failing to get an IP and my two RBS750s drop off and need to be restarted every couple of hours. I've not had any similar issues until I installed 4.6.5.14.
I'm steering well clear of it. Finally managed to stabalise my mesh and I'm not going to chance it. If it ain't broke, don't update.
