herzog57
Aug 04, 2024Aspirant
new RBS850 not connecting to RBR850
Hello all, I just bought a new RBS850. Tried to connect it to my RBR850 router....the light is purple /pink even if the satellite is just besides the router... what should I do? (please use a...
- Aug 05, 2024
That worked. Many thanks.
Michel
Aug 04, 2024Guru - Experienced User
- herzog57Aug 05, 2024Aspirant
Michel
- FURRYe38Aug 05, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
