RiKShaw
Nov 29, 2024Guide
New RBS850 Satellite showing blue LED but not connecting to router
Hello I recently received a new RBS850 satellite from an RMA. Here are the events of me attempting to get it connected. I plugged it in and waited. After a few minutes the LED showed solid blue...
- Dec 05, 2024
To close: I managed to get on a call with the support agent tied to the RMA. The router's firmware was incompatible with the routers so it wasn't able to connect. She was able to direct me to find the Satellite's IP address in the router's logs (Advanced - Administration - Logs) by comparing the MAC address from the label beneath the satellite.
Using the IP address I was able to connect to the satellite by just entering the IP address in my browser window while connected to the router (something that would fail before the RMA) and then follow the prompts to manually update the firmware. Once updated the router only took a minute or so before it corrected the backhaul status and was good to go.
RiKShaw
Dec 05, 2024Guide
Dec 06, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
