V1P3R007
Dec 08, 2022Follower
New (refurbished) Rbk752 - inconsistent speed/link rates
Hello, I upgraded my old RBK50 system to a refurbished RBK752 unit. (the RBK50 was refurbished as well and didn't have any issues for about 3 years so I had faith in the new refurbished one) Home is a...
Dec 09, 2022Guru - Experienced User
There's newer FW available: https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR750-RBS750-Firmware-Version-4-6-14-3-Released/td-p/2276312/jump-to/first-unread-message
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
