Jjersey63's avatar
Jjersey63
Apprentice
May 19, 2022
New setup, RBR760 and 2 satellites- backhaul poor on 5 GHz
Is there any way to force the backhaul status to use 2.4 vs 5?  The reason I ask is I get a backhaul status of poor on 5 GHz and good on 2.4 GHz.  But what I am finding is the satellites will drop to...
  • plemans's avatar
    May 20, 2022
    2.4ghz is significantly slower than 5ghz. Even in a poor status, the 5ghz is more likely still faster. Plus its a dedicated backhaul. When it uses the 2.4ghz, that 2.4ghz is then used for fronthaul and backhaul and it can't do both at once. So that link operates at 50% throughput of what it'd have because a satellite can't talk to the router and a device at the same time. Thats why dedicated backhauls became so popular.
    And the orbi will auto-negotiate to use the 2.4ghz if the 5ghz deteriorates to badly.
    so I wouldn't worry about it.
    (but no you can't force it)
