EdFerreira
Sep 14, 2021Apprentice
New V4.6.3.16
Hi all, Installed yesterday the new beta firmware V4.6.3.16. Got some improvements in the wireless connections but totally broke my lan wired stability. I have been quiet and reading the feedback bu...
Sep 14, 2021Guru - Experienced User
Wanted to check mine with RBS ethernet connected with v16.
Since mine was in AP mode already, I connected the RBS wirelessly first.
Once they were connected wireless, I connected them one at a time via ethernet, directly connected to the back of the RBR:
After the RBS was ethernet connected and up and running, I configured the RBR for router mode and let the system reboot while the RBS were ethernet connected. The system rebooted fine.
Checking one of the RBS, the web page is accessbile and I connected a iphone and a pad to the one RBS and ran a successful speed test on both.
I did not see any ARP storms or problems after the RBS connected via ethernet.
I didn't try adding a switch in to the mix.
EdFerreira
Sep 15, 2021Apprentice
wirelessly connected devices don't seem to be affected.
- AggedwNGSep 15, 2021ApprenticeGreat.. That confirms it for me. They didn't even bother addressing this issue in the new fw and my 90 day warranty just lapsed.. This is humorous at best, since this product cannot even provide it's most core function.. routing. So, what this boils down to, is they were more concerned with increasing their portfolio of "feature enhancements" over functionality. Proven by the fact they did not suspend rollout of 4.6.3.7 after complaints and intentionally disabled downgrading, knowing full well this was going to be an issue.. Us in the IT domain, know exactly what this is.. This is what happens when Marketing decisions trump development.. Netgear, your Product Management team needs to be shown the door.
- EdFerreiraSep 15, 2021Apprentice
Totally agree. This is a total train wreck. I'm a bit curious to know how many members has this development team. Messing up one of the most expensive products they have is laughable at least. Do they have management? No one is seeing this? And then there are a few guys here "trying" to help and wasting people's time doing so, doing trial and error testing when they know what they have done with this update. Where is the support? Problems created by their incompetence should labeled in a support contract? 2 months ago, the solution was flawed. They made it unusable with a firmware update. Who is going to give us back 2 months of not being able to use the devices? Total train wreck. Who is going to pick up the pieces? Not even a simple roll back solution...
- FURRYe38Sep 15, 2021Guru - Experienced User
You'll need to contact NG support and open up a support ticket as the forums can't seem to help you out.
https://www.netgear.com/support/#
Good Luck. - tak1313Sep 15, 2021Luminary
Haven't poked in here in awhile, since I put my AX in AP mode because my Asus is better at routing (also blocked updates some time ago because of this type of debacle after it was forced to update to a version I didn't want).
Just curious if they re-enabled the ability to downgrade with the beta, or if they're holding fast to their "we know what's good for you" mentality.
- AggedwNGSep 15, 2021ApprenticeI concur as well. Ridiculous is an understatement with how this is being handled..
For those of you shopping or considering this product, reading these forums, do your research first. Plenty of reasons to steer clear unless you like doing QA on a product that is being steered from a functional software development life cycle. Hard to believe this company is ISO certified.. - AggedwNGSep 15, 2021ApprenticeThey're holding fast.. Its likely apart of the model they've decided to take with this product. Which is why it was likely disabled in the first place.
- tak1313Sep 16, 2021Luminary
AggedwNG wrote:
They're holding fast.. Its likely apart of the model they've decided to take with this product. Which is why it was likely disabled in the first place.So another curiosity. Since the cat is out of the bag, and they know that some have figured out the F12 key method of enabling the "YES" button in the update page (if someone REALLY wanted to downgrade to stable), did the dark forces bork that ability in the 16 update, or did they leave it be?
- AggedwNGSep 17, 2021Apprentice"Dark forces"... lol. More like shady business practices.. It's likely still hidden in the html. As the previous poster confirmed, he was able to downgrade. I personally tossed mine in the closet and have been running on an old router with stable firmware. Seeing as they felt the need to hide it in the first place, shows their intentions of where they plan on going with this.. I might pull mine out and do some testing this weekend but I wouldn't hedge any bets on them reversing course on that.
- vmieleSep 17, 2021Guide
Well, probably, if they had released a working and well tested firmware, we wouldn't be here arguing about whether or not it is correct to hide a button.
- tak1313Sep 17, 2021Luminary
vmiele wrote:Well, probably, if they had released a working and well tested firmware, we wouldn't be here arguing about whether or not it is correct to hide a button.
That's why I decdided to move on awhile ago. After mine was updated without permission, I decided to put it behind my Asus router in AP for multiple reasons.
1. Asus gives FAR more control in routing
2. Asus does things for FREE that Netgear charges for.
3. To fully block updates
At this point, I am especially glad I did #3 when I did as it apparently saved a lot of grief.
Netgear just doesn't seem to have the most capable coders and they apparently don't sufficiently understand their own products. ALL tech products have issues, but the lack of proficiency, capability, and most importantly, customer support response is undeniably lacking. It's ridiculous that they maintain a pay wall and/or make it difficult for users to get support for a problem THEY created.
I got the Orbi because I needed a good mesh. I was going to stick with Asus, but decided to try Orbi since I had great experiences with Netgear stuff in the past. The Orbi is great at wifi, but nothing else (hence running it in AP mode).
Netgear - never again. When it's time to upgrade, it'll be anything but.
I've had a rbk20 for a year and a half with no problems.
I decided to upgrade and opted for the rbk753...I wasn't expecting this nightmare.
I still have time to return everything and opt for something else.
Let's see how this evolves... but given netgear's poor responsiveness.... I'm afraid I'll have to decide before they come out with a solution (assuming there will be one) - AggedwNGSep 17, 2021ApprenticeNo arguing here lol.. Fully agree with all sentiments expressed in this thread. It is a joke and one of the worst I've seen in a long time. I wouldn't hold your breath on anything productive coming from this.. If my return policy hadn't lapsed, I would have taken it back in a heartbeat. Whether it be due to poor implemented coding, Product Management or Release Support, for me they've shown their hand and I'm done with this brand.
- EdFerreiraSep 17, 2021Apprentice
AggedwNG wrote:
"Dark forces"... lol. More like shady business practices.. It's likely still hidden in the html. As the previous poster confirmed, he was able to downgrade. I personally tossed mine in the closet and have been running on an old router with stable firmware. Seeing as they felt the need to hide it in the first place, shows their intentions of where they plan on going with this.. I might pull mine out and do some testing this weekend but I wouldn't hedge any bets on them reversing course on that.Let me know how that goes... Mine is staying in the garbage bag until something happens. Probably in another 2 months, since they took 2 months to release a final beta version of the fw (this isn't even RC).
vmiele wrote:I've had a rbk20 for a year and a half with no problems.
Let's see how this evolves... but given netgear's poor responsiveness.... I'm afraid I'll have to decide before they come out with a solution (assuming there will be one)Return it. Look at it this way, you can see all the problems this ruckus is causing already. Let's say they are able to fix things before your return window is up, so you decide NOT to return it.
Netgear has shown their ineptitude in this type of situation, so you know at some point, your then working system (now past the return period) will be borked by another update/forced update and you'll be stuck with a bunch of network bricks.
I have already advised everyone I know that even IF NG can get passed this, you can depend on another "event" down the road with similar results.
I'm not knocking them for updating - ALL brands HAVE to update periodically, especially if it's a security issue. The difference is HOW problems with updates are handled by the back office.
