timroswell1
Apr 25, 2021Aspirant
Nexia won't connect to ORBI
HELP!!! I've tried calling customer support but no answer. Just purchased ORBI AX4200 RBK752. My Trane thermostat XL950 uses Nexia. Been unable to logon to ORBI. Nexia asks for SSID, shows my netwrok...
KMDonlon
Apr 25, 2021Virtuoso
Trane XL 824 here and using it as my Nexia bridge with my RBK852 system. No issues at all here... Have you changed your CTS values for 2.4ghz to 2347? Also, have you rebooted the thermostat and Orbi?
- timroswell1May 12, 2021Aspirant
Orbi tech support told me to uncheck Enable AX - This WiFi mode will enable AX features, Enable 2.4G box and no problems connecting.
- FURRYe38May 12, 2021Guru - Experienced User
Unchecking the AX box next to 2.4Ghz or 5Ghz will DISABLE AX mode. Putting a check in the check box will ENABLE AX mode.
timroswell1 wrote:Orbi tech support told me to uncheck Enable AX - This WiFi mode will enable AX features, Enable 2.4G box and no problems connecting.
