vnl
Jan 11, 2022Tutor
nginx proxy manager - Reverse Proxy Not Working
Long story short... I was too excited on getting the Orbi that I replaced my BT SmartHub2 and using the Orbi as the new router. I was able to take a csreenshot of the port forwarding required. ...
- Jan 12, 2022
Okay strangely. I think things have sorted itself out and I genuinely don't know how.
- I had to reset the Orbi.
- Restart the setup of the Orbi Router.
- Switched off my Pi and so the nginx proxy manager.
- Restarted my Pi and all the services (npm).
Everything seems to have magically worked now.
Thanks and sorry all. Seems like a the classic case of "Have you tried turning it off and on again"
CrimpOn
Jan 11, 2022Guru - Experienced User
How about doing the same thing on the Orbi router that you did on the BT Hub: forward ports 80 and 443 to the LAN IP address of the nginx proxy manager.
On the Orbi web interface (http://orbilogin.net), select the Advanced Tab, Advanced Settings, and the menu item Port Forwarding.
vnl
Jan 12, 2022Tutor
I have done the exact same.
- CrimpOnJan 12, 2022Guru - Experienced User
Does "CanYouSeeMe.org" report the same IP address as the Orbi WAN IP? (Orbi web interface, Advanced Tab, "Internet Port")
- vnlJan 12, 2022Tutor
CrimpOn wrote:Does "CanYouSeeMe.org" report the same IP address as the Orbi WAN IP? (Orbi web interface, Advanced Tab, "Internet Port")
Yes it does.
