vnl
Jan 11, 2022Tutor
nginx proxy manager - Reverse Proxy Not Working
Long story short... I was too excited on getting the Orbi that I replaced my BT SmartHub2 and using the Orbi as the new router. I was able to take a csreenshot of the port forwarding required. ...
- Jan 12, 2022
Okay strangely. I think things have sorted itself out and I genuinely don't know how.
- I had to reset the Orbi.
- Restart the setup of the Orbi Router.
- Switched off my Pi and so the nginx proxy manager.
- Restarted my Pi and all the services (npm).
Everything seems to have magically worked now.
Thanks and sorry all. Seems like a the classic case of "Have you tried turning it off and on again"
Jan 11, 2022Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? If this SmartHub, these usually have a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
vnl
Jan 12, 2022Tutor
FURRYe38 wrote:What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? If this SmartHub, these usually have a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
The Manufacturer of the device I am not sure, I will need to double check but it is for BT (British Telecom I think). It is the latest Hub they have which is called the SmartHub 2.
I have Fibre from BT and only the router provided. I can directly plug in the Orbi router completely replacing the BT Smart Hub 2. So I am not sure there is a double NAT issue as the ISP provided device is not in use (packed and returned to avoid any fees).
The port forwarding is set up excatly like I used to.
I am still researching the problem. I am thinking it has something to do with the fibre connection may be? I have a random white box with just 1 cable out of it, which was plugged to the ISP router. I have now plugged in the cable to Orbi. So every device is working like it should.. and amazing speeds.
Just my poor docker services cannot be accesed using the reverse proxy.
Thanks again.
- schumakuJan 12, 2022Guru - Experienced User
Not sure you are in the right community here ... either there is something conceptually complete off, like subnets referred not reachable or the like, ports used for multiple things, ...
For the Docker, I would start about here:
docker logs nginx-proxy
