dathomas's avatar
Dec 27, 2021
Nighthawk Mesh vs Orbi mesh
I am looking to move from a router/extender to a mesh system. I was looking at the Nighthawk MK83 mesh system and the Orbi RBK653 and RBK853. The MK83 and 653 appear to be comparable with the 853 higher end. I have an approximately 4000sqft house all on 1 level. The bedrooms are basically in the corners with the common living areas in the middle. The interior walls have inslulation. So everything is pretty spread out and the insulation I believe interfers with the signal to some degree. I have about 75 devices currently connected according to my Nighthawk app. I have several TV's with Roku's/Firesticks, several plugs, switches, cameras and other smart home devices. Laptops, tablets, and phones. My thought was to have an ethernet backhaul between the router and satellites and have the spread out to cover the house pretty evenly. So my questions are 1) is the 853 worth slightly over twice the price of the other 2 systems? 2) What would be the deciding factor between the other 2 systems, I don't see a huge difference between the 2 systems? Would I be able to add an additional satellite to any of the systems later if I decided it was necessary. I do own an EX8000 mesh router currently would it work with either system?
  • plemans's avatar
    If you're using a wired backhaul (not wireless backhaul), I'd skip the triband systems and go with a dual band. For the tribands, the 3rd band is exclusive to the wireless backhaul and if you're using a wired backhaul, its a bit pointless. I've got a SXK30 that is more stable and the same speed as my RBS750 system. And its half the price.
    So just to confirm, you're planning on the wired backhaul? If it is correct, I'd look at the SXK30 system or the MK63 system.
    I like the SXK because its business class. It tends to have a few more configuration options as well as tends to be more stable as there's more testing on the business class side.
    • dathomas's avatar
      dathomas
      Guide
      Thank you for your reply. My initial thought is to use a wired backhaul because it seems to me it would provide faster and more stable wireless connections everywhere as opposed to using a wireless backhaul. I am open to either but wired just seemed to be a better option. So you would not have any concerns with the lower speeds 1.8Gb vs 3 vs 6 with the number of devices, etc. on the network. I know that 75 isn't that large a number but since the documentation on most of these mentions 30 or 40 or 50 devices I wasn't sure what effect it would have to be a maybe twice the number they state. I am trying to get a stable and fast connection everywhere in the house which I have never had with the router/extenders that I have used over the years. I am chalking it up to the size of the house being as spread out as it is, the number of devices, and the insulation on the interior walls interfering with the signal as well.
      • CrimpOn's avatar
        CrimpOn
        Those throughput numbers are marketing hype, created by adding together the maximum theoretical speeds of each radio, along with a footnot in tiny type that says, "you will NOT get this. EVER."
        Insulation in interior walls is mostly for sound and 99% air.  Should not present much additional obstacle to WiFi signals.  Exterior insulation typically has foil vapor barrier, which will interfere with WiFi signals.
