dathomas
Dec 27, 2021Guide
Nighthawk Mesh vs Orbi mesh
I am looking to move from a router/extender to a mesh system. I was looking at the Nighthawk MK83 mesh system and the Orbi RBK653 and RBK853. The MK83 and 653 appear to be comparable with the 853 hig...
Dec 27, 2021Guru - Experienced User
If you look at the actual specs, it isn't until you get to the 8 or 9 series that the fronthaul is more than the 1800mbps.
spec wise:
SXK30: 1200mbps-5ghz and the 2.4ghz is 600mbps.
The RBK750 series front haul is: 1200mbps 5ghz and 600mbps 2.4ghz. Its backhaul is the 2400mbps. The backhaul is the dedicated wireless connection between the router/satellites.
So if you're wanting faster fronthaul, you'd need to go to the 8 series (RBK850) or the 9 series with the 6E connection
But you're getting pretty expensive when you jump up to those series.
dathomas
Dec 27, 2021Guide
Thank you very much for your help. I think I will probably go with the SXK30. If the number of devices won't cause me an issue. It looks like a good system and with your real world recommendation of stability, I think that is probably the best choice.
