Infocynic
Dec 22, 2021Aspirant
Nintendo switch won't connect to rbr750
I have looked through all the previous posts and updated my firmware, set cts to Max, disabled ax for 2.4 ghz (switch supports 5 ghz anyway), and disabled wmm for both 2.4 and 5 ghz. All the other dev...
- Dec 22, 2021I just did a factory reset and it seems like it's ok now.
CrimpOn
Dec 22, 2021Guru - Experienced User
Can you please describe which step fails during setup:
Infocynic
- Mikey94025Dec 22, 2021Hero
Infocynic wrote:
I just did a factory reset and it seems like it's ok now.Good to hear. FYI - I don't think you should ever need to disable WMM and nor does it improve compatibility with older devices, so suggest putting it back and seeing if things still work for you. Older 2.4Ghz devices are sometimes made more compatible with Orbi by setting CTS/RTS Threshold to 2347 or unchecking AX mode (but not disabling WMM).
- FURRYe38Dec 23, 2021Guru - Experienced User
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
