Infocynic
Dec 22, 2021Aspirant
Nintendo switch won't connect to rbr750
I have looked through all the previous posts and updated my firmware, set cts to Max, disabled ax for 2.4 ghz (switch supports 5 ghz anyway), and disabled wmm for both 2.4 and 5 ghz. All the other dev...
- Dec 23, 2021I just did a factory reset and it seems like it's ok now.
Infocynic
Dec 23, 2021Aspirant
Mikey94025
Dec 23, 2021Hero
Good to hear. FYI - I don't think you should ever need to disable WMM and nor does it improve compatibility with older devices, so suggest putting it back and seeing if things still work for you. Older 2.4Ghz devices are sometimes made more compatible with Orbi by setting CTS/RTS Threshold to 2347 or unchecking AX mode (but not disabling WMM).
