Rogelio1
May 12, 2020Apprentice
No Ability to Daisy Chain AX6000 (two satellites)
Just bought the 3 pack (1 AX6000 router and 2 satellites), and as far as I can tell there is NO ability to enable daisy chain topology. Here is the old (original orbi) settings for adanced wirele...
kildare
May 13, 2020Luminary
Currently in the Orbi AX the best possible topology is automatically selected by the system.
The best connection path should be calculated taking into account all the available hops and their actual transfer speeds.
So a daisy chain is selected if the system considers this the best available path (this happened to me too when testing the best satellite locations).
Then there is no need to be able to explicitly enable this feature.
Indeed the problem might be to know why the AX system now did not select a daisy chain topology...
