Rogelio1
May 12, 2020Apprentice
No Ability to Daisy Chain AX6000 (two satellites)
Just bought the 3 pack (1 AX6000 router and 2 satellites), and as far as I can tell there is NO ability to enable daisy chain topology. Here is the old (original orbi) settings for adanced wirele...
Rogelio1
May 13, 2020Apprentice
Disconnecting and turning on sequentially did not work.
Sat 1 is about 50 feet from router (router is in living room and sat 1 is down the hallway in an office).
Sat 2 is in a she-shed/cabana that is an additional 60 feet from sat 1 (so the distance traverses through the stucco wall of the main house) or about 110 feet from the router (as I mentioned it’s a strict linear distance).
The logic it’s using to connect at 2.4Ghz to the main router for sat 2 is faulty. The link connection is worse than the prior old Orbi as evidenced by my speed tests being half of what they were sitting beside sat 2.
I get Netgear trying to idiotproof the settings and have it dictate how it best thinks it should connect — but the logic is just plain wrong on their AX6000 Orbi unit for a second sat. There needs to be a satellite Advanced config page to manually set how it’s connected (I.e. daisy chain to first sat) and at what frequency.
May 13, 2020Guru - Experienced User
What happens if you try to swap RBS positions?
- Rogelio1May 13, 2020ApprenticeHoly crap — swapping the two satellites and plugging them in sequentially worked. It now shows them in a line / in daisy chain. (With the last sat connecting on 5Ghz)
Seems a bit temperamental in deciding when it wants to daisy chain. I still think there should be an override option.- FURRYe38May 13, 2020Guru - Experienced User
Glad that worked. Ya I guess it would be nice to have that check box like on the Orbi AC.
I would make a backup configuration to file for safe keeping. Please mark your thread as solved so others will know.
Enjoy. :smileywink:- Rogelio1May 13, 2020ApprenticeSo I went back and looked at the network map and it has reverted back to having each satellite connect to the router and disregard the prior daisy chain. Nothing was rebooted or reset.
Not having much confidence in this AX orbi’s firmware logic. AC Orbi always locked in on daisy chain and never reverted back when the topology setting was checked.
