Rogelio1
May 12, 2020Apprentice
No Ability to Daisy Chain AX6000 (two satellites)
Just bought the 3 pack (1 AX6000 router and 2 satellites), and as far as I can tell there is NO ability to enable daisy chain topology. Here is the old (original orbi) settings for adanced wirele...
Rogelio1
May 13, 2020Apprentice
Opened up a ticket and on hold with them now. I'm literally going to point them to this thread to document my issue.
Now it shows that my satellite in the shed/cabana is connected at 5Ghz to the router (which makes even less sense... I would expect it to either connect at 5Ghz to the other sat, or connect at 2.4Ghz to the router (not ideal, but at least some logic there).
29 days left to see if this Orbi can sort itself out. I can't imagine any setting (of which there really are none) will change its logic on 2.4 vs 5Ghz / daisy chain other than a firmware update. So far I'm unimpressed with how it's handling a second sat and think its firmware is likely still very buggy.
May 13, 2020Guru - Experienced User
Let us know how it goes.
