Rogelio1
May 12, 2020Apprentice
No Ability to Daisy Chain AX6000 (two satellites)
Just bought the 3 pack (1 AX6000 router and 2 satellites), and as far as I can tell there is NO ability to enable daisy chain topology. Here is the old (original orbi) settings for adanced wirele...
Rogelio1
May 13, 2020Apprentice
Haven’t tried the transmit power edits. I did try moving all three to the same room and resetting. Not surprisingly the says bonded to the router. Disconnected and put back into respective rooms one by one. Same problem as before. The furthest sat will show for the first minute it’s daisy chained to the other sat and backhaul for both is “good”. A minute later when I check both backhauls show poor and each sat is bonded to the router (even the far one) at 5Ghz.
The decision making of how the second sat is pairing makes no sense to me whatsoever. On the verge of returning these to Netgear — I suspect there was a reason why they didn’t sell second satellites for about 6 months (and I think it’s because their firmware logic is inconsistent at best and garbage at worst)
kildare
May 14, 2020Luminary
Without testing it's hard to say what actually means "poor" in terms of transfer rate, in comparison with a "good" daisy chain connection.
But IMHO one thing is sure: the double wireless hop due to the daisy chain topology increases a lot the latency, so this could seriously affect some applications like on-line games, video conferencing, etc.
So the solution choosen by the Orbi AX might have taken into account all the consequences of the available connections and have some reason behind.
In my case I tried all the possible satellite locations to avoid the daisy chain topology even if the wireless connection was good (see attached image), but I wasn't successful and eventually had to resort to a wired satellite connection.
