slosrt8
Nov 26, 2022Tutor
No Cable Connection Information
So after having an issue that was resolved. I found out that I have another issue. When I went to Cable Connection on my CBR750 it shows no information. See attached photo. I've had my ISP resend the...
- Dec 16, 2022
So to update this thread. After many more attempts at resetting the router/modem. We still had no luck it getting a factory rest completed. I ended up ordering another unit for testing and that unit worked as it was suppose to. This issue had started early in when I first purchased the modem. I contacted NG tech support, provided all the information they requested and they dropped the ball and didn't respond back to me for almost a month (When my warranty expired) and then closed my ticket, providing no resolution to the issue. A BIG THANK YOU TO FURRYe38 who helped me through the process and resolved my issue and got me a replacement modem/router from NG. So the only positive from NG is they helped FURRYe38 and sent me a replacement. NG tech support should learn from FURRYe38 about customer service and following through, to resolve the issue.
slosrt8
Nov 27, 2022Tutor
Hi. I posted a picture of the Cable Connection page in my original post. Here is the current firmware for my CBR750 and RBS750 running Windows 11
CBR750 V4.6.5.8_2.0.54
RBS750 V4.6.5.14
I have added a screenshot of the Cable Connection page again on this reply. There is nothing in the event log. I am guessing since the modem thinks it is offline it won't generate event logs as it isn't communicating with the ISP server. (I could be wrong about this)
Nov 28, 2022Guru - Experienced User
Your cable connections page showed none of the upstream/downstream info.
- slosrt8Nov 28, 2022Tutor
Yes I know. That is the information I provided in my first post. That the cable connection page isn't displaying any information. And the title says it as well. No Cable Connection Information. This is what I get when I click on the Cable Connection inside my Orbi
- FURRYe38Nov 28, 2022Guru - Experienced User
What browser are you using?
Does this happen in a different browser? Try MS Edge or Firefox...- slosrt8Nov 28, 2022Tutor
Current browser is Firefox and I have tried Microsoft Edge and Google Chrome with the same results. This is the page I get when I click on Cable Connection. Then I click on the highlighted Click here to go to settings, then it brings me to the information page with nothing on it.
