copieguy54
Aug 28, 2021Follower
No coax connector.
Ihave a model RBR750 router that does not have a coax connector. Instead it has a yellow ethernet connector labeled Internet. Do I need to order something else to make this work. My Spectrum modem ha...
- Aug 28, 2021
The RBK system doesn't have a built in modem be design. the CBK systems are systems with built in cable modems.
You can connect your RBK system ot your ISP cable modem. Contact the ISP for help and information regarding there modem.
Use the Installation and User manual guides for help and information on setting up the RBK system.
Visit the Orbi AX forum for additional information regarding the RBK7 series system:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Good Luck.
Aug 28, 2021Guru - Experienced User
Good Luck.
