marine0816
May 21, 2020Aspirant
No connected device found ios Android app
Orbi ax6000 firmware 3.2.11.2 "No connected device found" when connected to android app and iPhone app and looking at network map. What's the deal with this? Had same problem in last firmware update. ...
- May 21, 2020
There is newer versions of FW:
marine0816 wrote:
Orbi ax6000 firmware 3.2.11.2 "No connected device found" when connected to android app and iPhone app and looking at network map. What's the deal with this? Had same problem in last firmware update. Anyone else have this problem?
Thanks
May 21, 2020Guru - Experienced User
Thanks
