wifiblues
Jul 26, 2021Luminary
No Firmware listed
hi just set up a new RBK752 system - during set up through the orbi app, the app updated the router firmware to v3.2.18.1 when I opened the orbi app, i noticed the RBS750 showed no firmware. Wh...
Jul 27, 2021Guru - Experienced User
NG maybe auto updating certain sections or groups of products at a time, not all at once.
If you want to update, you can always manually update:
If your system is working, you can choose to NOT update as well.
Good Luck.
