firenut34
Dec 15, 2022Aspirant
No increase in speed after upgrading my service
I have the RBR750 and RBS750 x1. My house is 2 story 2700sqft. I have frontier fios and upgraded from 500/500 to 1gig and didn’t see any change in the numbers. Orbi app is showing 508 download and 510...
Dec 15, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
firenut34 wrote:
I have the RBR750 and RBS750 x1. My house is 2 story 2700sqft. I have frontier fios and upgraded from 500/500 to 1gig and didn’t see any change in the numbers. Orbi app is showing 508 download and 510 upload before and after. The RBR750 is connected to the ONT using a cat8 and set for router. I have changed the cat5 to the Cat8, upgraded to the latest firmware on both the RBR and RBS as instructed and factory reset the device and get the same readings, or sometimes less. The 5g is set to 48 and 2.4 is auto. Not sure what I should do next.
firenut34
Did the power offs, and same speeds on different devices and speed apps. With Frontier Fios, I only have internet so there isn’t an actual modem so it goes by Ethernet straight to the RBR750. After the firmware updates, I did a factory reset also.
