Jennifer99839
Aug 22, 2020Tutor
No Internet After Reboot RBK852/RBR850
My internet was working fine, then I rebooted the router via the Orbi app, and lost connection to the internet (The router dashboard reported "Not Connected" to internet). I connect to CenturyLin...
- Aug 22, 2020
FURRYe38 wrote:What Firmware version is currently loaded?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?When you factory reset the RBR and setup from scratch, did you power OFF the ONT for 30 seconds then back ON as well?
Thank you for the response. I realized I hadn't double-checked the VLAN settings and sure enough there was no VLAN setting, so I added that back and it started working.Thank you
Aug 22, 2020Guru - Experienced User
Jennifer99839
Aug 22, 2020Tutor
Thank you
- FURRYe38Aug 23, 2020Guru - Experienced User
Glad you got it working. Be sure to save off a backup config to file for safe keeping. Saves time if a reset is needed.
Enjoy. :smileywink:
