LucasRey
Nov 16, 2022Tutor
No internet connection with WAN Aggregation
Hello community, today I configured the WAN port aggregation using RBK850 WAN+LAN1 ports. Starting from a working config with a single WAN port, I did the following: Enable WAN aggregation on RB...
- Nov 16, 2022
OMG! This is clearly a wasting forum space thread 😅
The "newbie" issue was that I assigned, to the internet interface, an already used IP address... 🙄
Now, is working perfect, even if I got "only" 700 Mbps on my Samsung Galaxy s22+, while Orbi app reports 950 Mbps.
But that's ok for my needs, especially if I compare it with my last orbi RBR50
LucasRey
Nov 16, 2022Tutor
Nov 17, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
