David___
May 11, 2021Guide
No Internet via Orbi WiFi
Hello, I am using an Netgear Orbi model RBR850 with Firmware V3.2.18.1 and App Version 2.9.6.0. It is wired to a Vodafone Arris TG3442DE cable modem with 1000 Mbit and I am based in Germany. Arris h...
- May 24, 2021
Is the Orbi in AP mode?
Is ALL wifi radios on the ISP modem fully turned OFF?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is Armor or Traffic Meter enabled?
May 11, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
- FURRYe38May 11, 2021Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
