tvprich
Sep 16, 2022Aspirant
"No Internet" when connecting Orbi upstream from a switch
Hello. I have Orbi WiFi Router RBR760 that comes with two satelites. When I connect the router from an unmanaged switch (that is connected to main Cox-Cable Router, although all hard-wired connection...
Sep 17, 2022Guru - Experienced User
So you're connecting your orbi to an existing router?
What actual modem cox router?
Do you have the orbi in access point mode with the way you're connecting it?
Otherwise you're in a double nat.
