ReLFrEoD
Jan 26, 2024Aspirant
No longer showing attached devices after firmware updated to 7.2.6.21
Please help.
Jan 26, 2024Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
What browser are you using? Try a different browser? MS Edge or Firefox or Opera?
Be sure to clear out all browser caches.
- ReLFrEoDFeb 05, 2024Aspirant
Same results with different browsers. Router is restarted several times. This is a setup that includes two RBKE963 kits and eight RBSE960s. The second router is in AP mode and has a wired backhaul. Four of the satellites have wired backhaul installed. This is a 40,000 square foot commercial site. There are up to 200 devices connected to the network. Everything seems to be working, but I can't see any attached devices...
This is a business. I can't disconnect everything and everyone and shut the whole network down.
- FURRYe38Feb 06, 2024Guru - Experienced User
Was RBS updated prior to the RBR being updated?
Business or not, sometimes steps need to be taken to troubleshoot. Do it after business hours.
Not sure I'd be using a home class router system in a business of that size. Not really designed for business or that size of business.
If power cycling doesn't return the connected devices, a factory reset and setup from scratch maybe needed:
Should have a backup configuration on file as well to help save time if and when factory resets maybe needed:
- donawaltFeb 06, 2024Hero - Experienced User
Wow that could be anything, even a virus on the network. Is the second RBR interfering somehow? Is there an IP address duplicate? Have you tried accessing the RBR web page from another computer or phone/tablet? Can you access the other Satellites and/or AP by IP? I would definitely do some after-hours work - if none of those suggestions fixed it, I would try powering down the other router/AP and see if it clears up. If you have time and it's not too unwieldily I would power down everything, then power up just the main router and modem, and see if it works. Then start bringing things online.
All that said, I would definitely power cycle after hours, you would be amazed how much that fixes that even reboots do not.
