CEL44
Feb 22, 2023Tutor
No network for 30-60 seconds when roaming between orbi wifi6 mini satelites
I have four orbi wifi6 mini devices, setup as AP (not router) to have a good network coverage. It give the impression is works pretty well since my devices are never disconnected even when roamin...
CrimpOn
Feb 22, 2023Guru - Experienced User
CEL44 wrote:
But even if the Wifi signal is always high and never shows disconnection, application requiring permanent streaming like Radio, Whatsapp calls, IP telephony, are on hold for 30-60 seconds everytime I switch to another orbi AP.
Could you identify the devices which exhibit this behavior?
(brand/model of phone, tablet, laptop, etc.)
- CEL44Feb 23, 2023Tutor
Hi CrimOn,
Thx for taking time to help.
I can't say if it happens on Pc's since we use them without moving... đ
But it happens on all our smarphones. All Android, but Samsung (S21+, A53), Oneplus (Nord2), Huawei P30.
When not moving, the connection is stable at all location, no worry.
BR,
CEL
- plemansFeb 23, 2023Guru - Experienced User
What happens if you put the livebox in passthrough mode and the orbi in router mode?
Or the livebox in router mode with the orbi's ip address in its dmz with the orbi in router mode?
Just seeing if somehow the livebox is causing issues
Good one: I wish I could use this livebox in passthrough mode, but this is not offered... I contacted the hotline when I received it and they confirm they do not want to make this feature available. Not comment...
I didn't think about enabling a DMZ and putting the Orbi as router in this DMZ. It is a bit tricky since I also use the livebox as a switch for other equipments. So I would need to install another switch for that test.
If no other idea pops up I may have to do that test, but I'd prefer to give a chance to other ideas 1st.
