Teamgoroff's avatar
Teamgoroff
No wifi name displayed
PLease HELP!!! I have been trying to get my Orbi RBX50 setup all day.  It first seemed to be working correctly but then got caught in a loop when it tried to update the firmware.  After that It woul...
  • Bandito's avatar
    Bandito
    Dec 26, 2019
    The white flashing light on top means that the router is booting up.  If it doesn't stop flashing, that would indicate that it is stuck in some sort of boot loop, likely due to a failed firmware update.  If this is the case, I'm afraid that your only option is to seek a replacement unit.
