hh_orbi
Sep 13, 2020Aspirant
not meeting internet speed
Hi, I have 600Mbps download/25 Mbps upload internet service from Xfinity. I run a speed test on my Modem C3700-100NAS & Orbi WiFi 6 RBK753S-100NAS router via Ethernet cable. I was only getting 22...
hh_orbi
Sep 14, 2020Aspirant
Should I just drop the Orbi set up and just use Model: C6900 only?
Will this be enough for my internet 600Mbps download?
Thanks.
Sep 14, 2020Guru - Experienced User
If your on a 600Mpbs ISP service, you'll need a new modem. Something like a CM1000 then connect the Orbi behind this modem to achieve 600Mpbs on a wired connection. Check with your ISP to see what they support on there network first before buying. Wireless, depending upon your wireless device support and design, may max out at around 400-500Mpbs. AX devices should be able to see near 600Mpbs depending on there design and support.
hh_orbi wrote:Should I just drop the Orbi set up and just use Model: C6900 only?
Thanks.
