SD1976
Aug 23, 2022Aspirant
Not seeing Orbi Outdoor in Router
I am brand new to the ORBI router. I have a 750 with 1 satellite. I did not get sufficient signal to our detached garage to operate one camera and my garage door opener. Support recommended that I ge...
SD1976
I have the RBS50Yv2. It appears to be working fine. Outdoor signal is great. Just can't see it in the router – like it doesn’t exist.
CrimpOn
Aug 23, 2022Guru - Experienced User
Since it cannot operate as a "satellite" on the 750 system, it will appear in the list of Attached Devices as a device. Perhaps if you go through the entire list, there will be one device that you do not recognize?
- CrimpOnAug 23, 2022Guru - Experienced User
Another tactic is to look at the product label on the bottom of the RBS50Y and record the WiFi MAC address.*
If that MAC address appears in the table of Attached Devices, you have found it.
* Depending on how the RBS50Y was mounted, this may be physically challenging.
- SD1976Aug 23, 2022Aspirant
Finally got off support with Netgear and they confirmed it is defective so I am not nuts. I could not see the MAC address which was what my original issue was-it was not there. Replacement!!!
Since the garage door and camera are now working correctly, perhaps the satellite was not needed?
Do those devices show up in the Attached Device list?
