RobertMeeuwis
Jul 03, 2023Aspirant
Not showing Wifi 6e
Wifi 6e enabled but two different Iphone 14's not showing the Wifi 6e network
both connect only to the 2.4 and 5 ghz
On selecting other networks and connecting manually on both phones message
Network not detected/availlable
Perhaps it would be helpful to double check the technical specifications on the iPhone 14.
This site https://www.gsmarena.com/apple_iphone_14-11861.php
WiFi6 is not the same as WiFi6E 🙄
- RobertMeeuwisAspirant
Sorry forgot to mention I worked in ICT for 18 years
So yes I am aware they are not the same
Iphone 14 both are not mine so I did not check the specs which explains me not knowing they only run wifi6
So I guess mysterie solved
