Notwoke
May 23, 2021Aspirant
Number of Connected
"Stream, game and video call on up to 40 connected devices simultaneously — with zero buffering." Does this mean max 40 devices? I have 52. Will the AX4200 accommodate these?
- May 23, 2021
You can have more than 40. Its just that overall performance might drop a bit.
How many devices can my Orbi system support? | Answer | NETGEAR Support
May 23, 2021Guru - Experienced User
what actual device do you have? (ax4200 is a speed)
there's differences.
1. its usually 32 devices per band
2. most support up to a total of 250 devices
3. the concurrent usage is usually that 50-60 devices. But if half of them are high bandwidth devices, then its going to be a little different.
so a lot depends on what you're actually doing and if you're doing it at the same time.
