jeffreywilens
Dec 03, 2022Tutor
Numerous brief losses of connection with RBK760 mesh system
Got RBK760 system (router and 3 satellites) on Black Friday. Installed with assistance of technical support and nothing but trouble since. I noticed web pages were slow to load, zoom kept reporting...
jeffreywilens
Dec 16, 2022Tutor
Is there a model # seen for the Hitron modem please? EN2251 (I have found some online complaints about this modem but they date back a couple years)
Any Wifi Neighbors near by? If so, how many? Lots, at least two separate networks from neighbors including another Orbi.
What is the size of your home? Sq Ft? 5000
Is Armor, Smart Parental Controls or Traffic Meter enabled. No.
After getting back from vacation, I gave it another try with technical support but they ultimately just told me to request a replacement router. Apparently it went beyond their script.
The router and satellites are functional in part. I can get great speed although sometimes my phone next to a satellite might say data link is only 6 Mbps but then later it will be over 200 Mbps. That's on the Orbi app, which may or may not be accurate because even if it says data link is only 6Mbps, speedtest shows over 100 Mbps download. I also got some error messages trying to log in with some devices (such as a Tesla) "Unable to obtain IP address. Please check DHCP Server Settings."
Regarding some of your suggestions,
There was a button to disable SIP ALG, but I left it enabled.
I don't see a DHCP address pool, but it is set to get Internet IP address dynamically from ISP.
There is a button to Enable 20/40 MHz Coexistence, but nothing to specify 40 Mhz only. (there are preamble modes)
I tried channels at 1 and 40 but 11 and 40 were slightly less crowded.
Firmware is set at v6.3.6.4_1.2.68 for the RBR 760 router and V6.3.6.4 for the RBS 760 satellites
The biggest problem remains numerous losses of connection. Most of the time, the loss is only noticeable if I was trying to load a page, streaming video or because I am running Net Uptime Monitor. For example, between 12 noon and 11 pm, my desktop computer had 46 logged "fails" meaning ping tests failed 3 servers for anywhere between 5 seconds and 4.5 minutes. That's not counting when I intentionally took it offline while rebooting etc. During the longer disconnections the Windows 10 network symbol turned to "globe" meaning offline, but the other times Windows 10 did not recognize the interruption although you could notice it if you were browsing, streaming, etc. I suspect online gaming would be completely disrupted.
Summary: There are some issues with the mesh network but maybe those can be worked with, but there's something wrong with the router itself in terms of losing connectivity. (or the ISP Spectrum Time Warner is to blame but they say their equipment and service is fine) While I am waiting for a replacement Orbi router, I will try out the Spectrum router they have now provided me.
jeffreywilens
Dec 17, 2022Tutor
Also here's another bit of information, I ran a command ping -n 50 www.orbilogin.com
Pinging www.orbilogin.com [192.168.1.1] with 32 bytes of data
Reply from 192.168.1.1: bytes=32 time<1ms TTL=64
Reply from 192.168.1.1: bytes=32 time=1ms TTL=64
Request timed out.
Reply from 192.168.1.1: bytes=32 time=3ms TTL=64
Reply from 192.168.1.1: bytes=32 time=72ms TTL=64
Request timed out.
[then it kept going for the rest]
As you can see, I got two time out messages and another got stuck for 72ms. I ran another 50 and got a couple time out and an 80ms
I then ran a similar ping test for my IP address provided by the ISP and got 7 time out out of 50 attempts
This does not seem acceptable to me.
