Beneficia
Sep 21, 2024Aspirant
Obri Pro WIFI 6 System Extenders (RBS50Yv2)
Does anyone know if you can add MULTIPLE Range Extenders to an Orbi Pro Wifi 6 Mesh system? The system only allows 6 satellites and I would like to extend the coverege further outdoors. The one RBS5...
CrimpOn
Sep 21, 2024Guru - Experienced User
When connected to the AX series of Orbi systems, the RBS50Y is not a "satellite". It is a device connected via WiFi. No limit except for perhaps the total amount of traffic.
