BigSchu22
Aug 12, 2022Aspirant
Odd Internet Issues - Orbi Mesh WiFi 6 System
Hi, I've been successfully using a Orbi Mesh WiFi 6 System - AX4200 - 3 pack (RBK753) for about a year, but for several weeks now, I am experiencing annoying problems with one of the satellites. ...
- Sep 22, 2022
Try the wireless adapter. You can always add a ethernet adapter as well. Most on board or built in adapters I find work ok but add-ons can be more stable.
Aug 30, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
- BigSchu22Sep 13, 2022Aspirant
Hi there!
House is about 4000 square feet. Unfortunately, the Verizon services enter the house in a far basement corner, which is why I purchased the Orbi mesh system to begin with.
Hardware Version RBR750 Firmware Version V4.6.8.2_2.1.9 GUI Language Version V3.0.1.5_2.1.30.3 Operation Mode AP The Orbi router is in the basement corner near the Verizon router, the first satellite is on the first level sort of in the middle of the house, and the second satellite is on the second level at the other end of the house.
So, going top down, satellite - far left, satellite - middle, router - far right.
2.4 GHz channels are on auto. 5 GHz are 36 + 40 + 44 + 48(P).
I used WiFi analyzer when setting up, there were no overlaps with neighbors, and I just re-verified this a few days ago.
As I said, anywhere using WiFi in the house I'm getting 200-300 Mbps down and no interruptions. I only have weird connectivity issues on the desktop that is directly connected to the satellite on the second level via Ethernet. I'm constantly getting "you are not connected to the Internet" error, weird latency, web addresses not resolving, patches and automatic updates failing, emails won't send, dynamic web content won't load, etc.
No issue on any WiFi device.
Thanks again,
Andrew
- FURRYe38Sep 13, 2022Guru - Experienced User
Is it the only desktop that has this problem? Try a different wired PC connected to the RBS?
Try Swapping RBS with each other to see if problem follows or remains at this one location.
Try channels 1 and 40.
Basements are not good places for the main RBR. Concrete and steel will be problematic.
- BigSchu22Sep 21, 2022Aspirant
Good Morning!
The satellites are on separate floors, but they're both 30+ feet from the router.
Unfortunately, I had no choice but to locate the router near the Verizon router in the basement where the Verizon service enters the house... I can't run a CAT 5 cable upstairs due to the basement located next to a slab foundation.
However, I am NOT having any wireless issues, backhaul status is always "Good." All WiFi connected devices perform well, i always get 200-300 Mbps down.
I did change the wireless channels to 1 and 40 per your guidance.
I have also updated the router and satellite firmware to the latest version.
I updated my Intel NIC drivers as well.
I also switched the satellites as you requested last time, same issues. Only with Ethernet connected devices.
