jackuiowa
Jan 14, 2024Aspirant
Odd issue with xfinity wifi and RBR850 and two satellites--Bridge Mode issues
Current Firmware Firmware Version V4.6.14.3_2.3.12 I am having an odd issue with RBR850 system and two satelites. I currently use and RBR850 with two RBS850 satellites and have been running my ...
Jan 14, 2024Guru - Experienced User
If you hadn't changed anything on the Orbi system or on the ISP bridged mode, something would be at the ISP service level that could be causing this. Something to ask the ISP about to check there services up to the modem.
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
Also if all this doesn't work to help resolve, your system is behind in FW:
jackuiowa
I’ll try this again. Thanks for responding.
I have my firmware set to auto update. Is it safe to manually download and install the update?
