donawalt
Sep 06, 2024Hero - Experienced User
Odd temp problem on Orbi 850 network
My neighbor has an Orbi 850 and NG CM3000 modem, and they texted me with a problem. I am wondering if anyone has advice how to troubleshoot it if it happens again?
It's an RBR and 2 RBSs. Las...
Sep 06, 2024Guru - Experienced User
Try with the RBS turned OFF and just the RBR. Then turn on 1 RBS and test.
What channels are being used on the system?
Power cycle the system OFF for 1 minute then back On.
I see grainy video on my Android pad, when connected to a NG MR6150 series mobile router. Also I've found that if I watch the YT shorts a few times then select on a normal video, the app hangs. Been happening on my Android pad for past few months. Seen this with it connected or a Orbi system and Nighthawk system. I don't think it's a router problem, rather a app issue.
