Capth4u
Dec 18, 2021Aspirant
Old RBK50 wifi faster than new RBK852
Hello everyone, I have a 1 gig fios internet speed and we have a older Orbi RBK50. My wife does a lot of telahealth from home now and we have a few wifi 6 devices so I thought it was a good ...
Dec 18, 2021Guru - Experienced User
What are your wired speeds at the RBR?
When testing wireless speeds, turn OFF the RBS first to ensure it connects to the RBR first and run speed tests there.
What model Mac do you have? 20##?
What OSX version is installed?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Heres what I get with my Mac Book Pro OSX 12.2 beta, connected at the RBR at 1300Mpbs:
Capth4u
Dec 19, 2021Aspirant
Hello, I am testing on my new macbook air M1 2020 running the latest operating system. I also test from my iphone 12 pro max and see the same speeds wireless of course. I'm concentrating only on the router and I tested both wired and wireless. I test straight from the modem and the RBR. The ISP speed is about 880 and the wired RBR is about 740-770. The modem is a simple MoCA ethernet adapter and again I'm getting the correct speeds out of it.I test wireless right next to the RBR and on my coffee table 4 ft away ... I have already went through level 2 of the netgear tech support and they can't figure it out. We have a 2 story 2500 sqft home and understand that each house has different issues that can slow the wifi speeds but Im standing right next to the the RBR when testing OR 4 ft away on thr coffee table. Nothing is blocking the router. I appreciate any help provided
