Capth4u
Dec 18, 2021Aspirant
Old RBK50 wifi faster than new RBK852
Hello everyone, I have a 1 gig fios internet speed and we have a older Orbi RBK50. My wife does a lot of telahealth from home now and we have a few wifi 6 devices so I thought it was a good ...
Dec 18, 2021Guru - Experienced User
What are your wired speeds at the RBR?
When testing wireless speeds, turn OFF the RBS first to ensure it connects to the RBR first and run speed tests there.
What model Mac do you have? 20##?
What OSX version is installed?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Heres what I get with my Mac Book Pro OSX 12.2 beta, connected at the RBR at 1300Mpbs:
Capth4u
Dec 19, 2021Aspirant
I do use a MoCA Ethernet adapter (FCA251) for my modem (set to WAN - not sure if that is the correct setting between WAN/LAN/FULL).... this is what frontier gave me so I don't know if this is causing my speeds from the wall to the adapter to slow. My speed from the wall is between 750 and 800 today. So I go from coax to MoCA adapter then out ethernet to the Orbi router. I called frontier and someone will be out on Tuesday .... lets hope they like thier job and want to help instead of brush things off. Frontier around here isn't very helpful sadly. Even if my fios speed were 750 mbps I think I should get 600 mbps near the Orbi. Im getting 450-470 right now on wifi.
