njsteblay
Apr 11, 2020Tutor
Older Wifi Devices Not Connecting to Orbi Wifi 6
Orb Wifi 6 - Orbi AX6000 Tri-band Mesh WiFi 6 System Model: RBK852 I have an older Insignia Google Home device that connects fine to my older Wifi Router but won't connect to the Orbi Wifi 6. A...
- Apr 20, 2020
Yes, I posted in the other forum as directed. I increased the CTS/RTS Threshold to 2347.
Apr 18, 2020Guru - Experienced User
Any progress on this?
Are you using the same SSID name and PW as what you used on your prior router?
njsteblay wrote:Orb Wifi 6 - Orbi AX6000 Tri-band Mesh WiFi 6 System
Model: RBK852
I have an older Insignia Google Home device that connects fine to my older Wifi Router but won't connect to the Orbi Wifi 6. Any suggestions for configuration that allow older devices to connect?
njsteblay
Apr 20, 2020Tutor
