rgkruse
Jan 15, 2024Tutor
One device does not have internet when connected to RBS860 satellites
I recently setup a NETGEAR Orbi RBR860 with two RBS860 Satellites. All devices except for one works great on the system and flawlessly transitions between router and satellites. Satellites are within...
- Jan 16, 2024
SOLVED! It was an Orbi settings setup error... When trying to get Orbi to talk to Starlink, (spoiler - you need an Uncontrolled Switch) I selected "Use Computer MAC Address" for "Router MAC Address". The computer was fine when connected to the router, but failed when connected to the satellites. I realized I forgot to set it back to "Use Default Address" and once I did, problem solved. Thank you for your help, CrimpOn.
CrimpOn
Jan 15, 2024Guru - Experienced User
This error appears to be common enough on Windows 10 for a search on "No internet, secured" to turn up LOTS of hits. and it seems as if you may have tried a number of the suggested solutions already.
The router has software that compares the hardware MAC address of the network interface (Ethernet or WiFi) against a table of Organizationally Unique Identifier (OUI) codes:
https://en.wikipedia.org/wiki/Organizationally_unique_identifier
There are web sites that do this, such as:
https://www.wireshark.org/tools/oui-lookup.html
My guess is that when the router attempted to look up the OUI code for the Lenovo laptop, it did not come up with a match to Lenovo. (Maybe the WiFi card was not built by Lenovo?)
Can you check to see if this laptop has the WiFi feature to randomize the MAC address for WiFi connections?
- rgkruseJan 16, 2024Tutor
This explanation is extremely helpful, thank you! The MAC address through "ipconfig /all" matches the one shown on the Orbi device list. Also, my WiFi settings does have the ability to randomize addresses, but the feature is not turned on (generally or for my specific network).
Good call on just exploring more into the "No internet, secured" error. My WiFi adapter is an Intel(R) Wi-Fi 6 AX201 160MHz (OUI returns "B0:60:88 Intel Corporate") and I think I'll look into specific issues with this adapter next. Thank you for your help!
- FURRYe38Jan 16, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
