Rbs750User
Oct 18, 2022Aspirant
One Laptop Won’t Connect to Network when RBS750 is Plugged In
I’ve had the same set up for ~2years with one RBR750 and 2 RBS750s. Monday morning one Dell laptop wouldn’t connect to the internet. It connected to the wifi network but with the description “No ...
- Oct 19, 2022
After a bunch of trial and error the lack of internet to the Dell didn’t seem to be related to one of the specific satellites. I could reset or disconnect one or the other satellite and the internet would instantly “click on” on the Dell, but as soon as I rebooted it was gone. I tried resetting the devices, moved them around, tried disconnecting devices, assigning a specific IP address to the laptop etc… nothing seemed to solve it.
Eventually, I just factory reset the RBR750 and both RBS750s, set the whole system up as new with a new SSID, and that seems to have done the trick. Everything has been working for about 12 hours now.Who knows….
Rbs750User
FWIW the wifi driver on the Dell is AX201 160MHz. But none of the variables have changed recently to my knowledge (i.e. the Orbi firmware or the Dell driver).
- FURRYe38Oct 18, 2022Guru - Experienced User
Sounds like something wrong with this one device. Might try a different adapter.
Something to contact the Mfr of this PC about.
