Rbs750User
Oct 18, 2022Aspirant
One Laptop Won’t Connect to Network when RBS750 is Plugged In
I’ve had the same set up for ~2years with one RBR750 and 2 RBS750s. Monday morning one Dell laptop wouldn’t connect to the internet. It connected to the wifi network but with the description “No ...
- Oct 19, 2022
After a bunch of trial and error the lack of internet to the Dell didn’t seem to be related to one of the specific satellites. I could reset or disconnect one or the other satellite and the internet would instantly “click on” on the Dell, but as soon as I rebooted it was gone. I tried resetting the devices, moved them around, tried disconnecting devices, assigning a specific IP address to the laptop etc… nothing seemed to solve it.
Eventually, I just factory reset the RBR750 and both RBS750s, set the whole system up as new with a new SSID, and that seems to have done the trick. Everything has been working for about 12 hours now.Who knows….
Oct 19, 2022Guru - Experienced User
Its specific to the one satellite?
If so, I'd try reinstalling the firmware to that satellite to see if maybe something was corrupt with it.
Best option would be the manual firmware update process on that satellite. (not the auto).
Just power off the working satellite to ensure you're not installing it to the wrong one.
