Rbs750User
Oct 18, 2022Aspirant
One Laptop Won’t Connect to Network when RBS750 is Plugged In
I’ve had the same set up for ~2years with one RBR750 and 2 RBS750s. Monday morning one Dell laptop wouldn’t connect to the internet. It connected to the wifi network but with the description “No ...
- Oct 19, 2022
After a bunch of trial and error the lack of internet to the Dell didn’t seem to be related to one of the specific satellites. I could reset or disconnect one or the other satellite and the internet would instantly “click on” on the Dell, but as soon as I rebooted it was gone. I tried resetting the devices, moved them around, tried disconnecting devices, assigning a specific IP address to the laptop etc… nothing seemed to solve it.
Eventually, I just factory reset the RBR750 and both RBS750s, set the whole system up as new with a new SSID, and that seems to have done the trick. Everything has been working for about 12 hours now.Who knows….
Rbs750User
Oct 19, 2022Aspirant
Who knows….
- FURRYe38Oct 19, 2022Guru - Experienced User
There any big differences between the prior SSID name you had been using and this new one?
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
