Retired_Member's avatar
Retired_Member
Jun 30, 2022
One of my satellites is still using the standard admin/password login
I have a strange problem with my Orbi 853 system. The system is running stable on the new v4.6.8.5 firmware. One of my satellites is still using the standard admin/password login. The other one is sy...
  • FURRYe38's avatar
    Jun 30, 2022
    Factory reset the one RBS, then turn it OFF. Take the RBS to near or same room as the RBR.
    On the RBRs web page under Connected Devices, select the remove button next to the row that has the RBS showing as disconnected. After the one RBS is removed, reboot the RBR and wait for ready.
    Turn ON the RBS. When the front LED on the RBS slowly blinks WHITE, press the sync button the RBS then on the RBR. Wait a few minutes. The front RBS LED should turn BLUE.
    Check the status on the RBRs web page for the 2nd RBS. Should show GOOD and not Out of Sync. Give it about 5 minutes.
