LofiFTW
Jun 08, 2022Aspirant
One of my satellites (which was working perfectly fine a few weeks ago) will NOT connect to the rout
I am having the exact same problem with the exact same settings as the original author.
4000 sq foot home, router and two satellites are all downstairs. System worked perfectly fine for 2 years...
LofiFTW
I have connected the "bad" satellite to the router with my ethernet cable; I then log in to orbilogin to check but the satellite still does not connect, it does not have an IP address and does not give me an option to update firmware.
Jun 08, 2022Guru - Experienced User
Try updating the other RBS to v.2 first, then the RBR lastly. Then see if this one that won't connect, might connect after. Turn it OFF until you get the other RBS and RBR updated. Then try this other RBS.
